It is currently Sat Jul 19, 2025 7:02 pm
PostPosted: Thu May 21, 2009 8:52 pm
First name: Daniel
Last Name: Green
City: Milford
State: Ohio
Zip/Postal Code: 45150
Country: U.S of A
Any info on how to make continuous backplates would be a big help.
Thanks in advance.
:mrgreen:
PostPosted: Thu May 21, 2009 11:11 pm
Daniel,
what's a back plate? I'm assuming you don't mean back do you?
PostPosted: Fri May 22, 2009 8:42 pm
Hi Daniel,
My electric guitars are all "sandwiches" with a thick core and two guitar backs as skins. I cut the cavity cover from the inside of the back before it is attached to the core. I cut it with a dremel with a V-shaped cutter so as to get the smallest gap possible when viewed from the outside.
If you are building a solidbody, you can take a body blank thicker than what you need and remove a plate from the back, the plate being the thickness of your desired cavity cover. Then, by cutting the cavity cover from the plate at the exact position where it will be installed on the guitar, you will have a very similar grain pattern.
Note that I always laminate a cross-grain veneer from the inside of the cavity cover to prevent splitting.
Hope this helps!
Marc
PostPosted: Sat May 23, 2009 11:46 pm
First name: Daniel
Last Name: Green
City: Milford
State: Ohio
Country: U.S of A
Marc, Thanks alot, That makes since now i think about it. Could you explain alittle bit more about the last part "Note that I always laminate a cross-grain veneer from the inside of the cavity cover to prevent splitting". I really love the look of a continuous backplate, especially if you are using quality wood, its almost a must in my opinion.
Jim, A continues wood backplate is a cover for the electronic cavities, alot better then the cheap plastics.
This is an Alembic back plate from thier alpha omega guitar.
PostPosted: Sun May 24, 2009 10:05 am
You can also do continuous grain covers on solid (not laminated) bodies.
Here's one on a quarter sawn sapele electric.
I thickness the body using a router on rails, and leave it unthicknessed over the cavity cover positions. Then I cut of the covers with a saw, and final thickness and shape them to get a perfect match.
PostPosted: Sun May 24, 2009 10:17 am
Hi Daniel,
Since the backplate wood is only about 1/8'' thick, I always fear that it will split along the grain. I therefore remove about 0.030'' from the unseen face and laminate a maple veneer with the grain lines at 90 degrees from the backplate to strengthen it!
Here's a photo of one of mine in ovankhol.
PostPosted: Mon May 25, 2009 6:39 am
First name: Erik
Last Name: Hauri
State: Maryland
I cut mine out with a scroll saw using the thinnest blade I can find. And if you're going the extra mile for continuous grain, go all the way and use rare earth magnets instead of screws to hold the cover down.
The member formerly known as erikbojerik....
PostPosted: Mon May 25, 2009 7:06 am
Location: Between Bordeaux and the Atlantic. S.W.France
My feelings exactly Eric. Or, at least, use black ones like Setch. What a pity to put ugly chrome or nickel plated screws on those beautiful backplates.
PostPosted: Mon May 25, 2009 11:13 pm
Last Name: Shaw
City: Philadelphia
That does add a very nice touch to the guitar. I'm going to have to look into this idea. It sure beats ugly plastic. I have always wanted to eliminate plastic use all together from my stuff. I have made wood pick guards and control plates but out of contrasting woods to the body. The method you are showing is much nicer.
PostPosted: Fri Jun 05, 2009 4:19 pm
First name: Trevor
Last Name: Lewis
City: Crownsville
Zip/Postal Code: 21032
FYI, I think I remember reading that Alembic uses a laser to cut their back plates...
http://www.PeakeGuitars.com
PostPosted: Fri Jun 05, 2009 6:23 pm
First name: Daniel
Last Name: Green
City: Milford
State: Ohio
Country: U.S of A
Laser cut backplates??
Somebody's movin on up.
With 15k - 20k+ price tags, I guess they can afford it
PostPosted: Tue Jun 09, 2009 4:09 pm
First name: Todd
Last Name: Lunneborg
City: Andover
State: MN
Zip/Postal Code: 55304
The other option not stated here is to book match an electronics "cavity cover."
I cut my back plate in 3 sections. From my billet I'll cut the book matched drop top (back), say 3/8ths-ish, and I'll also cut a thinner 1/8+ plus plate. One that I can use for the cavity cover, Pick-up ring top laminate, back of the headplate and whatever else I'd like to match or inlay. Since it's book matched the grain difference is slight. I've also seen (and built) where the drop top (back) is the cavity cover. This allows for a thicker piece of wood that you can route the inside for switch clearance and leave bulk so it's not just a 1/8 (or less) piece of wood that can get punctured by someones rockin' studded belt in the midst of a "arm swinging 'rock their socks off' stage moment." I don't know about you cats, but that's how I play and sometimes the extra bulk is worth it.
Todd Lunneborg
http://www.tlguitars.com/
http://www.fretboardjournal.com/
